Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - GP's Silver Sleeper
Old 02-13-2013, 10:23 AM   #15
Jgrove998
Boost Addict
Jgrove998's Avatar
Fan#: 45311
What I Drive: 2004 SVT Turbo
Points 6,350, Level 51
Points: 6,350, Level: 51 Points: 6,350, Level: 51 Points: 6,350, Level: 51
Level Up 50% Completed
FF Reputation: 25 Jgrove998 Great Standing Member
Buy-Sell-Trade Rating: (13)
Originally Posted by GreenPanther View Post
The hose I noticed can be viewed through the opening through the intake manifold on the right side, behind the manifold. It connects to a black plastic piece at a 90* angle from the hose. I believe that is the PCV valve I am looking at. The hose appears to be completely collapsed and is split open like a hot dog on the top.
Is there a way to replace just the hose without removing everything else to get down in there? I also need to find a place to order the parts I need, because there is no way I am paying almost $500 to have someone else do the job.
You are correct, that is the PCV valve. If it is split your loosing already metered air after the MAF which could be playing into your bad gas mileage.
You have to remove the intake manifold to do any work on the valve or hose. I've done it twice by myself in less than 4 hours.
Tousely Ford Parts is the place to get OEM parts.
2004 SVT: bewst'd!
2013 Escape SEL 2.0 Ecoboost 4WD
2004 F350 6.8L V10 4x4
1986 XR4Ti 2.3L Turbo, 15 psi
Jgrove998 is offline
