Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Driver side door lock problem - Requires a locksmith
Old 02-13-2013, 04:02 AM   #3
TerryB
TerryB's Avatar
Fan#: 34559
What I Drive: 2001 Mustang GT Premium
Points 5,708, Level 48
Points: 5,708, Level: 48 Points: 5,708, Level: 48 Points: 5,708, Level: 48
Level Up 79% Completed
Level up: 79% Level up: 79% Level up: 79%
FF Reputation: 69 TerryB Excellent Standing Member
There may be a plastic clip that broke off. On my son's Mustang, he has the same problem. There is a rod the connects the lock cylinder to the door lock. Put the window down and try to look at the bottom of the door with a flashlight. See if there's any loose plastic pieces there. You may want to remove the door panel if you can't see from the top. I see it's a Fiesta so I'm not sure if it's the same door trim procedure.
http://www.myfordfocus.com/how-to/doortrim.htm
TerryB is offline
