Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Stereo questions
Old 02-12-2013, 01:43 PM   #16
HoneyBadger
Fan#: 104860
What I Drive: 2012 Ford Focus SEL
FF Reputation: 1 HoneyBadger Good Standing Member
Originally Posted by TheDriver916 View Post
It would be more of a pain to mess with fuse panel. Personally I wouldn't cut corners when your dealing your electronics. Just run everything to the battery and head unit (if you decide to add that) the conventional way.
Are you talking about having a stock aftermarket head unit?
My thoughts were to tap into the wires on the 8 inch sub, to connect to my amp. The amp would have a wire directly for power from the battery. The little blue wire (Tells the amp when the car is on), could be connected in the fuse panel in the back. When I say connect I am talking about adding a second fuse to the one. I just don't know if any of them turns on with the car or not. I will need to get a diagram for it.
HoneyBadger is offline
