Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Symptoms of a valve seat about to drop?
Old 02-12-2013, 09:05 AM   #22
GUM85
Fan#: 109288
What I Drive: 2006 Pitch Black ZX4 ST
Points 366, Level 7
Points: 366, Level: 7 Points: 366, Level: 7 Points: 366, Level: 7
Level Up 32% Completed
FF Reputation: 1 GUM85 Good Standing Member
I guess you can test it electrically but not mechanically. Autozone's web site says to test the IAC on 2000-2005 focus disconnect the two pin electrical connector, using a digital multimeter do a resistance test at the two pins on the IAC valve electrical connector and you should get a reading between 6-15 ohms if the reading is out of that range replace the valve. I did this test on the IAC valve on my car and got a 0 ohms reading. If I did it correctly than my IAC valve is no good. I just don't understand why it would run worse after I took it off and cleaned it.
GUM85 is offline
