Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Surfaced Head and Adjustable Cam Gears
Old 02-11-2013, 08:35 PM   #10
sdaddy
sdaddy's Avatar
Fan#: 105173
What I Drive: Green 2002 Birkin w/2L Zetec
Points 139, Level 2
Points: 139, Level: 2 Points: 139, Level: 2 Points: 139, Level: 2
Level Up 78% Completed
FF Reputation: 1 sdaddy Good Standing Member
Originally Posted by amc49 View Post
The discussion is a moot point, he probably read the degrees difference on the sprocket markings, irrelevant since the reason for the adjustable sprockets to begin with. You correct with them back to right, or what you want. There is no way to 'confirm' since every engine will be slightly different. The term '5 degrees' also useless unless knowing retard or advance and which one of two cams.
The TDC mark can be useless too since may not be true TDC which needs to be indicated out with a degree wheel. Simply bumping a stop point pin is close but all engines vary there too.
Yes, you're right. I did mean the degree difference on the sprocket markings when the cam's are aligned via the tool. I checked TDC by using a the measuring end of a caliper on #1 piston and it corresponds to hitting the stop point pin. The adjustable sprocket markings are actually both 6 degrees retarded. I'll start with that and follow Tom's compression advice for the initial tuning.
sdaddy is offline
