Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Another question, haha.
Old 02-11-2013, 02:45 PM   #3
04ZTSJelf
04ZTSJelf's Avatar
Fan#: 319497
What I Drive: Mk3
Points 3,766, Level 38
Points: 3,766, Level: 38 Points: 3,766, Level: 38 Points: 3,766, Level: 38
Level Up 78% Completed
Forum Activity 4%
FF Reputation: 7 04ZTSJelf Good Standing Member
Originally Posted by rambleon84 View Post
It is recommended that you replace the struts/shocks when you lower your car. Yes, your car should be fine in the short run with those lower springs but they will quickly destroy your shocks/struts. If you are replacing your struts anyways, just get the FRPP shocks/struts, do it right the first time and it will save you work and money in the future. It will also handle and perform better, so the right way means replacing shocks/struts at the same time
You do not need to add a rear sway bar but if you do not have one, then adding that will be beneficial to your overall handling. I suggest a 21-22mm rear bar and poly bushings/endlink bushings. If you do not have the mounting for one, Steeda makes a kit that allows you to attach one.
I also went ahead and moved this thread to the suspension section.
Thank you for your help and for moving this to the correct section. I will check out that steeda kit.
MK1 2.3 sedan aka 'Pete' - gone
Mk1 zetec sedan - gone
MK3 sedan aka 'rePete'
04ZTSJelf is online now
