Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Another question, haha.
Old 02-11-2013, 10:46 AM   #2
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 9,799, Level 66
Points: 9,799, Level: 66 Points: 9,799, Level: 66 Points: 9,799, Level: 66
Level Up 38% Completed
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
Buy-Sell-Trade Rating: (15)
It is recommended that you replace the struts/shocks when you lower your car. Yes, your car should be fine in the short run with those lower springs but they will quickly destroy your shocks/struts. If you are replacing your struts anyways, just get the FRPP shocks/struts, do it right the first time and it will save you work and money in the future. It will also handle and perform better, so the right way means replacing shocks/struts at the same time
You do not need to add a rear sway bar but if you do not have one, then adding that will be beneficial to your overall handling. I suggest a 21-22mm rear bar and poly bushings/endlink bushings. If you do not have the mounting for one, Steeda makes a kit that allows you to attach one.
I also went ahead and moved this thread to the suspension section.
rambleon84 is offline
