Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SPI Parts list for head swap
Old 02-11-2013, 12:24 AM   #5
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
One of the benefits of a 'New' cast head is the known mileage - ZERO. If you use your parts from your head you at least know the mileage on them too.
A rebuilt head has an unknown amount of mileage and is most likely damaged, albeit vacuum/pressure tested. Plus it is rebuilt with parts with unknown mileage. Rebuilt could mean recycled two, three or more times and populated with parts tossed into a bin/floor.
This is the 'New' cast head company: J&C Enterprises Cylinder Head, 1-800-266-5599
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
