Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Surfaced Head and Adjustable Cam Gears
Old 02-10-2013, 09:53 PM   #6
sdaddy
sdaddy's Avatar
Fan#: 105173
What I Drive: Green 2002 Birkin w/2L Zetec
Points 139, Level 2
Points: 139, Level: 2 Points: 139, Level: 2 Points: 139, Level: 2
Level Up 78% Completed
FF Reputation: 1 sdaddy Good Standing Member
Originally Posted by Magus2727 View Post
Your timing belt will likely have more flex and adjust in length due to tension and thermal expansion. You should be setting you timing TDC so should still not mater...
Yes, setting timing TDC with cams held with flat tool at the back end. Comes out at 5 degrees ( at the cams) off. Just wanted confirm.
sdaddy is offline
