Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2001 focus zx3 manual trans clunking barely engages
Old 02-10-2013, 07:11 PM   #27
Fan#: 109390
What I Drive: 2002 Focus ZX3 Dark Shadow Gray
Points 369, Level 7
Points: 369, Level: 7 Points: 369, Level: 7 Points: 369, Level: 7
Level Up 38% Completed
FF Reputation: 1 FoMoCus Good Standing Member
My car is an 09/01. I'm hoping new shift cables will be the only snag, but in trying to research the part numbers it seems the junkyard trans may have been from a SOHC 2.0. I'm not sure if the bellhousing is the same between the sohc and dohc but I can always just swap the bellhousing if the differential will work with my zetec. I've also read some swap threads on here and some people say the axles need to be swapped. I don't know if I'll be in that boat or not.
FoMoCus is offline
