Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Who's replaced the head and not piston(s)??
Old 02-10-2013, 06:00 PM   #5
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
When you drop a valve seat the chunks get caught between the piston and head. It does a good amount of damage to both but the outer edge of the piston gets beat up pretty good. Enough to compress the lands and pinch the top ring so it no longer floats. A ring that doesn't float will probably wear out quicker than it should.
As someone else pointed out - did you clean out the broken valve seat parts from the intake/exhaust and EGR?
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
