Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Shift Tower Roll Pin Question - Please Help
Old 02-10-2013, 03:13 PM   #9
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,825, Level 100
Points: 32,825, Level: 100 Points: 32,825, Level: 100 Points: 32,825, Level: 100
Forum Activity 38%
You see that collar that the pin is in- that pin should be flush with both sides. It appears to be broken by your picture although it might look like it is in place. Does that collar move with the big weighted shift arm, or does it stay still. Have you checked to see if you were able to move the pin in the shift selection area?
Furthermore, are you stuck in a gear or neutral- did you check when you removed the shift tower?
What were your original symptoms? Describe what happened?
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
