Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - two lighting questions (Wiring)
Old 02-10-2013, 12:35 PM   #5
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,833, Level 100
Points: 32,833, Level: 100 Points: 32,833, Level: 100 Points: 32,833, Level: 100
Forum Activity 38%
Moved to Ford Focus Mk1 discussions. Yeah, it seems like this is all interior mods, but it's supposed to be body mods too. General Technical Chat is for technical discussions relating to general maintenance, electrical issues, engine trouble, and recalls. In other words, fixing problems. Thanks for posting!
FYI: I personally don't like the methods mentioned here for bypassing the relay because I don't like putting things under a relay. Another more difficult method is to identify that relay socket, turn the fuse box over, and tie those 2 wires together with a "suitcase" electrical connector designed for putting 2 wires together. Remember, your brights rely on this relay as well, so if it were to become loose, you'd have no brights.
I have no problem with bypassing the relay's function because- in this case- the fog lights are basically switched by the light switch not the relay. What you have is a normally open and normally closed combination relay- 6 pins, 2 small pins, and 4 large pins. If you flip the relay over, you'll see small numbers beside each pin. those correspond to the relay diagram on the side of the relay. The NO pins are for the brights. The NC pins are for the fogs. That's why you can't have both at the same time. In the case of the brights, the toggle switch switches the relay coils- not the power of the brights. In the case of the low power fogs, the switch itself is sufficient.
Do what you want, many people have done it like described, and I know of no problems. As a 20+ year veteran of electrical work, I just can't recommend doing it like that.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
