Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Alternator problem, please help
Old 02-10-2013, 10:07 AM   #18
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,403, Level 29
Points: 2,403, Level: 29 Points: 2,403, Level: 29 Points: 2,403, Level: 29
Level Up 69% Completed
Level up: 69% Level up: 69% Level up: 69%
Buy-Sell-Trade Rating: (3)
I'd be looking at continuity of the grey wire, in particular. The problem would seem to be somewhere in your wiring harness. Have you tried using a temporary duplicate wire i.e. wired up something outside the factory harness?
P1246 - Generator Load Input Failed
The PCM monitors generator load from the generator/regulator in the form of frequency. The frequency range is determined by the temperature of the voltage regulator where 97% represents full load, below 6% means no load.
Causes:
Generator circuit short to GND
Generator circuit short to PWR
Generator circuit open
Generator drive mechanism
Damaged generator/regulator assembly
Damaged PCM
Verify battery voltage is 14.5V.
Verify generator/regulator has the correct part number.
BC_ZX3 is offline
