Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - just baught some super bright leds
Old 02-09-2013, 09:15 PM   #23
blade08
blade08's Avatar
Fan#: 104798
What I Drive: 2008 Silver Focus SE Sedan
Points 308, Level 6
Points: 308, Level: 6 Points: 308, Level: 6 Points: 308, Level: 6
Level Up 16% Completed
FF Reputation: 1 blade08 Good Standing Member
Originally Posted by indy_11 View Post
here's my contribution to the forum
step 1: pull clear plastic off closest to the front of the car
step 2: once pulled all the way out find 4 clips holding the clear plastic piece in place
step 3: once plastic piece is removed the problem is getting the bulbs out. as you've probably already seen they're a pain to grab. so, what I DID (there could be other ways but i found this easier) was bend the metal surrounding the bulbs in order to reach in and grab them easily with my fingers and pull out.
step 4: replacing the bulbs. it doesn't really matter how you put them back in. i personally put the metal back in its place and then put the bulb in. but whatever works for you is fine.
finally: reverse all the steps to take the map light out and you could get a result like this
I really like how they look. They shine bright enough at night to which it isn't overbearing. I'll be sure to put pictures up of the night time later.
Can you reupload the pics? :)
blade08 is offline
