Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - motor issues
Thread: motor issues
Old 02-09-2013, 07:27 PM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 33,110, Level 100
Points: 33,110, Level: 100 Points: 33,110, Level: 100 Points: 33,110, Level: 100
Forum Activity 65%
Activity: 65% Activity: 65% Activity: 65%
Vibrations while moving and vibrations while sitting still with the engine on can very easily have 2 different causes. Now if you have vibrations with the engine off- you should probably run because the big one is coming!
Our usual suspect is the passenger side, or front engine mount. Poke around on the rubber part with your finger. If you find soft spots, then the mount has probably lost it's fluid, and that's what is causing your problem.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
