Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2005 2.3L ZX3 - FSWerks 2871R, 387WHP - PERFECT, TURN KEY
Old 02-09-2013, 11:34 AM   #13
SYZ
FocusFreak
SYZ's Avatar
Fan#: 31122
What I Drive: toxic waste
Points 8,246, Level 61
Points: 8,246, Level: 61 Points: 8,246, Level: 61 Points: 8,246, Level: 61
Level Up 32% Completed
FF Reputation: 106 SYZ Excellent Standing Member SYZ Excellent Standing Member
Buy-Sell-Trade Rating: (14)
Originally Posted by Andrew View Post
So what can one expect running strictly 91 pump?
Around 370ish WHP if you were going to just run 18-19psi. For the 387whp run, all we did was turn up the boost and added 100 octane to prevent any possible detonation. It spiked around 22-23psi briefly and held 21 psi to redline on that dyno run.
Frankly, this car is really quite fast for the street as it is. I'm running about 18-19psi when I drive it on 91 octane and I can break the 235 series tires loose on the highway at 55-60mph quite easily. The Apexi-AVCR boost controller is tapped into the ECU and can do boost-by-gear which definitely helps control wheelspin in 2nd and 3rd gear, but if you want to, you can certainly light up the tires by a simple button press on the EBC.
2015 Honda Fit LX 6 spd, stock
2015 Porsche Cayman S w/ mods..
SYZ is offline
