Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Getrag SVT 6 Speed Swap - Complete w/ Quaife and SB Clutch
Old 02-09-2013, 07:48 AM   #1
AcIdBuRn02ZTS
Fan#: 42027
What I Drive: 2002 Twilight Blue ZTS Sedan
FF Reputation: 5 AcIdBuRn02ZTS Good Standing Member
Desc: Getrag SVT 6 Speed Swap
Contact: AcIdBuRn02ZTS@yahoo.com, PM
-Complete SVT 6 Speed Swap-
Asking Price : $(New Price - $2800) or best offer
Includes: (All parts with ** are new from Steve @ Tousley Ford)
SVT Getrag 6spd Trans : ~60k miles when purchased
Quaife LSD: ~15k miles
Stg. 4 South Bend Clutch Kit - 7k miles (Custom built by Andy @ Southbend Clutch - Rated @ 450 Lb. Ft. - Street Friendly - Includes 12# flywheel)
**SVT Axle Shafts w/ Axle Nuts (Nuts have been retorqued twice... Ford suggests replacing after 4 uses)
**Axle Seals
**Shifter Cables & Alignment Tool
** Cranks Position Sensor Mount (same as MTX-75... will provide if needed)
**Clutch Master Cyl.
**Slave Cyl.
Clutch Hyd. Lines
SVT Shifter Base
Pedal Assembly
SVT Trans Wiring Harness
Anything else swap related that I cant think of at the moment... possibly the pass. carrier bearing mount.. cant remember if this was a required piece or not... if it is, I'll include it as well.
The trans shifts like butter. The Quaife was professionally installed and works flawlessly. The shifter counter weight has been removed (I think I still have it) which makes the shifts feel much more crisp and controlled with a lighter throw of the shifter. Clutch setup has worked great and is very streetable. My car was originally an auto so I will be including everything to swap from an auto to the 6 speed.
I dont have many pictures of this stuff... but I'll see what I can come up with.
Here are a few from when I did the swap.. everything is still in the car currently.
I prefer these items be picked up due to the cost of freight shipping. I am willing to ship but it will be at the buyers expense. Deposit required before I will remove from the car.
Thanks
-Chris
2002 - Twilight Blue ZTS Sedan
Built Motor, Getrag w/ Quaife, Eibach Suspension, GT3071R Turbo.. Destroying Tires thru 3rd @ 10psi = Priceless. 20+psi soon to come.
1987 MKIII Supra Targa
AcIdBuRn02ZTS is offline
