Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Oil change time!
Old 02-08-2013, 10:45 PM   #17
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 31,641, Level 100
Points: 31,641, Level: 100 Points: 31,641, Level: 100 Points: 31,641, Level: 100
Forum Activity 100%
If you're still doing those road trips this summer, you'll be in the right area for the "FocusFest" !!!
With the Motorcraft oil avail. at WalMart (Ford Parts Guy actually was the first to send me there, they had it cheaper than his cost) I stick to the Factory Fill for now. Synthetic blend is decent stuff & mine gets low miles between changes so it works for MY use pattern. If I did a lot of miles, or "Track Days", I'd prob. upgrade to Mobil 1.
The Motorcraft & Wix recommendations are common, NAPA Gold gets some votes (Wix product?). Only other filter comment from me is to change it MORE often than Oil, NEVER less! Some Folks used to change it every other oil change, but it's been shown through oil analysis that filtration is MORE important than changing out oil that's still good. Getting the crud out is what counts, so cleaning the oil is good. When doing extended oil change intervals with synthetics, changing the filter at "normal" drain intervals is generally recommended.
One "Bud" of mine has kept a 944 going more than 25 yrs. of HIS ownership with Mobil 1, including track time & there are lots of similar stories. Changing it is more important than brand, you'll notice many brands will guarantee your engine if you use their products religiously!
luck!
sailor is offline
