Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ĦĦĦMassive Speed Focus Rear Camber Arms 00-13 Focus ALL V2.0 Official Release!!!
Old 02-07-2013, 03:02 PM   #1
K Dog
K Dog's Avatar
Fan#: 23554
What I Drive: Car
Points 17,811, Level 84
Points: 17,811, Level: 84 Points: 17,811, Level: 84 Points: 17,811, Level: 84
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Buy-Sell-Trade Rating: (19)
We've completely re-invented our ever popular RaceSpec Rear Camber arms for 2013.
We wanted MORE - more adjustability, more strength, more cool factor, more reliability, more ease of use. After exhausting research, a grueling 14 hour endurance road race in October and having plodded the streets of Chicago for last 6 months, we present to you, Version 2.0 - truly MORE!!!!
Here's what we have to say about them:
Replaces stock fixed arm with adjustable. Allows for custom camber settings:
  • Obtain stock settings – many stock/mildly dropped vehicles cannot be set to OE specifications. Massive arms allow alignment to be perfect resulting in optimal handling and proper tire wear.
  • Performance/racing settings – Tune for more advanced settings for max race performance in road race / autocross environments.
  • Allows for extreme drops and radical wheel/tire installations. If your – tucking – slamming – stretching – chopped – screwed – flush, you need these.
NEW VERSION 2.0 offers many advantages!!!:
  • Billet aluminum construction is far stronger than either thin OEM or others tubular steel designs, while still offering light weight.
  • Includes machined steel double adjuster sleeve allowing full ON CAR adjustability!!!
  • Supplied with neoprene rubber rod ends boots to keep the elements out – a must for any car that actually gets driven!
  • Adjuster is placed closer to same plane as the attachment point offering a far greater range of adjustment.
  • Identical in weight to factory unit, an astounding 1 pound 7 ounces LIGHTER (per side) than the other guys porky adjustable cast iron arms!!!
Years of exhausting research at the race track and on the street have led us to the “cost-no-object” Aurora swaged PTFE lined oversize 5/8” 15,000 lb rod end used. This spherical joint provides the highest in accuracy for ultimate motion control AND extremely low noise operation for the long haul.
Custom made high durometer polyurethane bushing minimizes unwanted deflection and is maintenance free.
All threaded items supplied pre-coated with Permatex anti-seize compound to ensure long term operation.
Custom made Massive Billet Big OD offset bushings provide extended range of motion, tight fastener clearance for noise reduction and large load bearing surface for max strength.
Included is the Massive exclusive Hardcore Hardware kit – Yellow Zinc plated grade 10.9 190,000 lb tensile strength hex bolts replace your worn, rusted weak factory stuff.
As always – made in house here in the USA!!!
Available in your choice of anodized Signature Massive Purple, Gloss Black or Conspiracy Components texture black.
Just $207.13!!! For the rest of February, get 5% off - your cost just $196.77 - PLUS get a FREE T-SHIRT!!!
Our new "On my Grind" shirt will let folks know where your mind is at. Premium 50/50 Poly/Cotton 6.1oz "ringer" shirt in heather grey and black neck/arm trim. Printed in bold fluorescent orange graphic. You choice of any size small through XXL.
Still just $5 SHIPPING
Enter code: BILLETISBETTER
You must ADD the shirt to your order (in the apparel section) in the size of your choice to receive it.
Find them Here
Fitments include:
FORD
1999 - 2013 FOCUS
MAZDA
2004 - 2013 3
2006 - 2010 5
VOLVO
2008 - 2013 C30
2004 - 2010 S40
2005 - 2010 V50
massivespeedsystem
K Dog is offline
