Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - High Beams will not toggle anymore after service
Old 02-07-2013, 01:31 PM   #9
Kabigon
Fan#: 88299
What I Drive: 2012 sterling gray Titanium
Points 5,736, Level 48
Points: 5,736, Level: 48 Points: 5,736, Level: 48 Points: 5,736, Level: 48
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 5%
FF Reputation: 11 Kabigon Great Standing Member
Originally Posted by Pinion Dominion View Post
The high beams "work" in autolamp mode. Pressing (and holding) forward on the turn signal lever turns the high beams on. But as soon as I stop pressing forward (ie. releasing the lever), the high beams go off (so it's in "flash-to-pass" mode).
But before the service, doing this same action, the high beams would remain on. To turn the high beams off I would push the lever forward again then release (I call this toggling - you don't need to keep holding something to keep the effect, it just toggles on and off based on further pressing/de-pressing).
You fail to mention the obvious. Are the headlamps themselves on or off???
Of course it will make a difference as to how the high beams operate.
I am Kabigon and I approve this message.
Kabigon is offline
