Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - High Beams will not toggle anymore after service
Old 02-07-2013, 01:04 PM   #8
Pinion Dominion
Pinion Dominion's Avatar
Fan#: 105589
What I Drive: 2012 White Platinum Focus Titanium
FF Reputation: 4 Pinion Dominion Good Standing Member
Originally Posted by lewisra View Post
So do they work in auto mode? When your car goes in for service they will usually turn auto mode off.Since you have DRL's you may not have noticed.
The high beams "work" in autolamp mode. Pressing (and holding) forward on the turn signal lever turns the high beams on. But as soon as I stop pressing forward (ie. releasing the lever), the high beams go off (so it's in "flash-to-pass" mode).
But before the service, doing this same action, the high beams would remain on. To turn the high beams off I would push the lever forward again then release (I call this toggling - you don't need to keep holding something to keep the effect, it just toggles on and off based on further pressing/de-pressing).
Pinion Dominion is offline
