Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Replacing my catalytic converter
Old 02-07-2013, 08:51 AM   #11
tmittelstaedt
Fan#: 108093
What I Drive: 2001 Red Focus SE Street Edition
Points 313, Level 6
Points: 313, Level: 6 Points: 313, Level: 6 Points: 313, Level: 6
Level Up 26% Completed
Forum Activity 8%
Activity: 8% Activity: 8% Activity: 8%
FF Reputation: 2 tmittelstaedt Good Standing Member
Hmmm....I suspect that either one of 2 things happened. Either when they were fixing the evap system the mechanic discovered one of the O2 sensors was unplugged or the sensor was just loose and tightened it, or when they cleared codes, it erased both codes and whatever is setting the P0422 code is only doing it intermittently. In which case if you have emissions inspection next month you might be able to slide through. If the light goes on again just go to an auto parts store and ask them to clear the codes and see if the light stays off for a while.
tmittelstaedt is offline
