Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Outside Temperature Incorrect - 2012 Focus
Old 02-06-2013, 06:38 PM   #31
kemoe
Fan#: 109270
What I Drive: 2012 Ford Focus
FF Reputation: 1 kemoe Good Standing Member
In the past, Ford has changed things due to customer complaints. For example, Ford used to put oil pressure gauges in lots of different vehicles. Customers complained that the oil pressure would drop at idle- especially in the summer with the AC on. Nobody sued back then, but there were plenty of complaints. Ford then put a resistor in the oil gauge circuit, and changed the sender to a switch- now oil pressure remained steady as a rock, until it would drop to nothing at 7 psi about 1 second before the engine locked up.
I hope Ford will get on the ball and fix this horrible issue for you. How can a 21st century digital man such as yourself survive without knowing the exact outside temperature? Maybe we'll get one of those famous Ford fixes. Instead of actual temperature- what if it simply said: Icy Cold, Cold, Sort of Cold, Warm, Hot, Sweaty Stinky Hot, Hot as Death? Then you'd know exactly what you were up against.
You might want to sue your weatherman too. I've noticed that they are off by as much as 5 degrees every day.
Wow thanks, that was really helpful.
kemoe is offline
