Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Time for front end work?
Old 02-06-2013, 03:59 PM   #2
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,540, Level 22
Points: 1,540, Level: 22 Points: 1,540, Level: 22 Points: 1,540, Level: 22
Level Up 40% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
If you're satisfied with an OEM ride, then Monroe QuickStruts are a cinch to install (assuming your hardware is not horribly corroded) and probably your cheapest option. While you're at it, put some SensaTrac shocks on the rear (although based on comments on the forum, the wagon's rear shocks are not as easy to replace as other Focii).
Also, the rear LCA cam bolt internally seizes on older Focii, resulting in a frozen toe setting and LCA's that only come off with a cutting tool. So, if you're being really proactive and plan to get an alignment anyway, then you might wanna think of some way of mitigating that corrosion.
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
