Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - High Beams will not toggle anymore after service
Old 02-05-2013, 10:22 AM   #2
ccelaya's Avatar
Fan#: 92465
What I Drive: 2012 Sterling Grey - Focus HB Sport
FF Reputation: 1 ccelaya Good Standing Member
Originally Posted by Pinion Dominion View Post
I took my Focus to the dealer for an oil change a couple of days ago. (+ they repaired my mykey feature).
Last night, while driving I noticed that the toggle function of the high beams does not work anymore. I am referring to page 121 of 5th printing manual where it says "push the [turn signal] lever toward the instrument panel to activate". Before, when I did this, the high beams would stay on after pressing it.
Now, it will just act as a "flash-to-pass" a la what happens when you pull the lever towards you.
So now, pulling and pushing the lever becomes "flash-to-pass". Not very convenient to hold the lever down if I want continuous high beams..
Has anyone ever experienced something like this?
Yes I have, when your toggle is on the "parking lights" position, the high beams only work as a "flash-to-pass".
Make sure your toggle is on the "full-on" position, and try to switch to high beams with the lever.
I hope that helps.
ccelaya is offline
