Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Does no one proofread the Owners guide? - 2013 Ford Focus
Old 02-04-2013, 06:32 PM   #4
suss6052
suss6052's Avatar
Fan#: 95752
Points 12,272, Level 72
Points: 12,272, Level: 72 Points: 12,272, Level: 72 Points: 12,272, Level: 72
Level Up 56% Completed
Forum Activity 3%
Buy-Sell-Trade Rating: (3)
Originally Posted by Yanner View Post
This is in jest, but the above, also, could use some proofreading.
If you understand the engineering behind what I said it was perfectly clear.
Instead of the engine combusting fuel to drive the wheels through the transmission when the fuel is shut off the engine is driven by the wheels instead. The engine takes the energy from the wheels to continue to pump air while no fuel is injected into the cylinders. This does cause the car to slow down more aggressively than if the transmission was disconnected from the wheels by depressing the clutch and putting the car into neutral.
suss6052 is offline
