Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Rattling in the engine bay?
Old 02-04-2013, 06:47 PM   #14
drummer829
Fan#: 71497
What I Drive: 2005 liq grey ST
Points 3,858, Level 39
Points: 3,858, Level: 39 Points: 3,858, Level: 39 Points: 3,858, Level: 39
Level Up 39% Completed
FF Reputation: 1 drummer829 Good Standing Member
Originally Posted by VillageT View Post
Yup- its called an exhaust heat shield. You can reinstall it by using fender washers (small hole-large OD) instead of the factory ones where the thing is supposed to attach. If you can safely get under the car you can fix it for about $5. You can get the washers from any good parts store or an ACO.
SO i need to get my oil changed and having just moved I have no tools other than a few phillips and a flat head screw driver. Do I really need that exhaust heat shield, or can i just pull it out. Also, if I bring into ford for an oil change, do you think they will do anything to help me out
drummer829 is offline
