Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - HID on third gen focus, WITH DRL
Old 02-04-2013, 03:42 PM   #16
klotche
klotche's Avatar
Fan#: 91834
What I Drive: 2012, Oxford white, Focus
Points 5,854, Level 49
Points: 5,854, Level: 49 Points: 5,854, Level: 49 Points: 5,854, Level: 49
Level Up 52% Completed
FF Reputation: 3 klotche Good Standing Member
Originally Posted by twinbiker11 View Post
Anyone tried putting in 55 watt ballast and seeing if they work without resistors or relays?
In my idea, it wont work, cause you still need anyway a relay harness, which means your connected to only 1 OEM plug (driver side for me..), so you need 1 resistor to avoid bulb out error on passenger side...
Plus, DRL on those focus are giving only 9 volt, which isn't enough to run those ballast... so you can't imagine running them without that relay harness.
There is more fact that makes me think it won't work with DRL, but that much summarize it
klotche is offline
