Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Tubular rear lower control arm's
Old 02-04-2013, 01:07 PM   #20
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 23,917, Level 94
Points: 23,917, Level: 94 Points: 23,917, Level: 94 Points: 23,917, Level: 94
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
Forum Activity 100%
FF Reputation: 79 felixthecat Excellent Standing Member
Originally Posted by teamDFL View Post
Yes. His arms are unacceptable. In reality, only a small amount of adjustment is needed. A nearly straight arm or one with just a bend for the spring pocket would be preferred. Plus, like your camber arms, a rod end on one end would be excellent.
Thats what I always thought too. Seeing most of the pix w/ the spring pocket jacked up, for the shorter, lowering springs.
Originally Posted by hurtinfocus View Post
the old focus-central arms are awesome IMO....
20120903_163231.jpg[/IMG]
you can kind-of see them in ^ this pic on my car....they are totally straight and have a cup in them to mount the swaybar endlinks, mine however are upside-down from the last time I had it aligned they re-connected them upside-down and I didn't notice/look until MONTHS later, going to need a re-alignment this summer anyways so I'll flip them back correct when that gets done
It also helps that the old Focuscentral arms mounted their coilovers in to the top shock mount which is great. I supose all the other manufactors(coilover) think the top shock mount won't take the load.
felixthecat is offline
