Old 02-03-2013, 06:34 PM   #1981
sgmfocus
sgmfocus's Avatar
Fan#: 101095
What I Drive: 2012 sgm sedan se,sfe package
Points 299, Level 5
Points: 299, Level: 5 Points: 299, Level: 5 Points: 299, Level: 5
Level Up 98% Completed
FF Reputation: 3 sgmfocus Good Standing Member
Originally Posted by Zillon View Post
I removed the endlinks entirely and ziptied the sway bar tight with heavy duty wire ties, with tension in both directions (up and down). That thing wasn't moving anywhere.
Regardless of what I did, the noise didn't improve when I removed the endlinks or mass dampers.
The last thing I did prior to trading the car was reinstall the stock dampers, strut bearings, mounts, and associated hardware. The noise got worse after reinstalling the factory bits.
Zillon ,when you unhooked the endlinks on the front sway bar how did the car handle ?did you notice an increase in side to side movement(rocking),or any changes in handling on your test drive. thanks
sgmfocus is offline
