Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Replacing my catalytic converter
Old 02-03-2013, 04:38 PM   #5
tmittelstaedt
Fan#: 108093
What I Drive: 2001 Red Focus SE Street Edition
Points 313, Level 6
Points: 313, Level: 6 Points: 313, Level: 6 Points: 313, Level: 6
Level Up 26% Completed
Forum Activity 8%
Activity: 8% Activity: 8% Activity: 8%
FF Reputation: 2 tmittelstaedt Good Standing Member
Before swapping the cat out, replace BOTH the upstream and downstream O2 sensors with new sensors and see if the check engine light goes away. it will cost about $100 for 2 bosch sensors from the parts place but you may just have a bad sensor. This is a DIY project you just need a O2 socket, a socket wrench, and a jack and jackstands.
And, if this does not fix it then if you buy a brand new cat to replace it, you will find the small print requires that you replace all O2 sensors when you replace the cat or the manufacturer will not warranty it, so it's not money down the rathole.
Where I live every cat that comes into a wrecker goes straight to the metal recycler, you can't find used ones that way.
tmittelstaedt is offline
