Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Play in wheel
Thread: Play in wheel
Old 02-03-2013, 12:11 PM   #1
Sapperstang
Fan#: 27847
FF Reputation: 1 Sapperstang Good Standing Member
Buy-Sell-Trade Rating: (-1)
Play in wheel
Wifes car has 170K and is making a noise from the front right. When driving very slow, as in coming to a stop light you can hear what sounds like a grind or something. It is not constant and sounds like it has to do with the wheel turning. If you can imagine a grind coming from something turning you will have a sense of what I mean. Doesn't do it all the time and goes away as you get faster.
I went out and raised the car and there is a decent amount of play in the right front. I can move the wheel at least a cm back and forth in all four directions. The brake rotor moves as well of course. I lowered it and made sure the lugs were not loose and they weren't. Nothing looks out of place either.
I checked the left front and there is no play at all in that wheel. So it seems maybe the ball joint? I understand it is easier to replace the lower control arm instead of just the ball joint. Want to make sure this sounds consistent with a ball joint before I do anything.
Thanks.
03 zx3
Sapperstang is offline
