Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Snorkel Delete
Thread: Snorkel Delete
Old 02-03-2013, 10:40 AM   #11
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 41,631, Level 100
Points: 41,631, Level: 100 Points: 41,631, Level: 100 Points: 41,631, Level: 100
Forum Activity 18%
Activity: 18% Activity: 18% Activity: 18%
FF Reputation: 54 dyn085 Excellent Standing Member
Buy-Sell-Trade Rating: (5)
When you remove the airbox lid, you lose the negative pressure in the ducting that leads to the radiator support opening. This will cause your intake to be consuming mainly underhood air. Even with a fabricated shield to emulate the big-name companies, you will still acquire a certain amount of heat-soak.
That being said, I don't think that it is overly detrimental. There will be a bit of cool air forced through the ducting due to the pressure difference of the front of the radiator support and the intake box along with some cooler air that enters around the headlight. I inspected the sealing of the Typhoon when it was on my car for testing and found that there was actually a large amount of area for underhood air to bypass the shield. Just looking at pictures of the Steeda intake I would have to assume the same applies to it as well.
All of that being said, my best recommendation is always to experiment. What works for me and my commute does not necessarily apply to anyone elses. I wanted my power to be lower in the rpm range. This allows me better response and fuel mileage. If I drove in a more 'spirited' manner and was willing to spend more money, I would be sporting a name-brand intake...
I have been toying with the idea of wrapping some of the tract though...
FocusFest 2013: Best of Show
Gateway FFW: Show Class Outstanding
September '13 ROTM
2014 FiST-
dyn085 is online now
