Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Guess what im doing (future build teaser)
Old 02-03-2013, 09:21 AM   #21
Jeffrosilver07
Jeffrosilver07's Avatar
Fan#: 104592
What I Drive: 2007 Silver Focus SE
Points 559, Level 11
Points: 559, Level: 11 Points: 559, Level: 11 Points: 559, Level: 11
Level Up 18% Completed
FF Reputation: 3 Jeffrosilver07 Good Standing Member
Hey Zetec got a question for you figured you would know. So we have talked in other posts before about systems that we are doing or have done. I know you build SPL vehicles which is awesome and alot of fun. I used to do that as well but now I am building my a SQ focus. My question is with all the power/current your pulling what type of alternator are you using. Mainly I'm wondering because I need to get something alittle larger to accommodate my new system. It doesnt need to be to crazy Im thinking between a 150-250 amp alternator. Even that might be overkill. The amps that I'm using are 3 Mosconi AS line amps with a combined fuse rating of 240 max. The 3 amps are internally fused at 80 each. I personally will never use the max fuse rating.
I know what I need to run everything I was just wondering where you are getting your alternators. I have looked into Ohio Generator and Stinger but wasnt sure if you were using one of those or just getting yours custom spun at a shop.
Good luck with the build. Ill post more of mine soon.
Jeffrosilver07 is offline
