Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Replacing my catalytic converter
Old 02-02-2013, 11:35 PM   #4
Fan#: 109481
What I Drive: 2000 grey ZX3
FF Reputation: 1 Zeroe31890 Good Standing Member
Oh i'm sorry. You are probably right. Thanks for correcting me.
Originally Posted by BC_ZX3 View Post
For starters, the ZX3 was only ever fitted with the 2.0 liter DOHC (Double Overhead Cam) engine. The SOHC engine type you've quoted is not the correct one.
New catalysts are expensive due to the materials that go into making them. Finding a used one at the junkyard may be a better bet if cost is an issue as 1) you're ensured a correct fit and 2) cost will be considerably less than a new one.
Catalysts can be diffcult to remove if you have only a basic tool set. You need to remove the upstream 02 sensor (requires a special socket) and undo a large EGR tube nut. Rusty fasteners through out can also be problematic.
Zeroe31890 is offline
