Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - HOW TO: IMRC Removal and Repair
Old 02-02-2013, 08:50 PM   #107
Fan#: 100097
What I Drive: 01 zx3, 2002 SVTF, 2004 Silver euro
FF Reputation: 1 stanger19899ddr Good Standing Member
This is a great post
My SVT was getting the dreaded IMRC check engine light when I found this post
Figured I would try to fix my module today after I retuned from the salvage yard.
I found a unique thing today I think
While I was walking around I found a duratec 24 valve engine in and decided to look inside the IMRC Module The 99 and new have the short cable.
Took the screws loose fo the circuit board Wiggled the connector and the circuit board and the motor are easily removed.
Turned the gear with the cable on it and the cable slid out. It even had the same number on the box as my 02 foocus SVT. YOu can clean the contact and whatever else you need to do and dont have to unsolder anything.
ALSO found out a 96 Contour duratec 24 valve V6 engines module is a dirct replacemnt for the SVT. Just put one in mine and cleared the light
stanger19899ddr is offline
