Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Rattling in the engine bay?
Old 02-02-2013, 03:52 PM   #9
drummer829
Fan#: 71497
What I Drive: 2005 liq grey ST
Points 3,858, Level 39
Points: 3,858, Level: 39 Points: 3,858, Level: 39 Points: 3,858, Level: 39
Level Up 39% Completed
FF Reputation: 1 drummer829 Good Standing Member
Originally Posted by VillageT View Post
The noise seems to be responding to loading from the engine rocking in the mounts however I had a similar noise in my 2005 that drove me nuts for about 20K miles. I was sure it was coming from the right rear but it turned out to be the front swaybar links.
They are plastic and they are crap! If you haven't replaced those disconnect one side and check for a loose ball end. As one of the other responders noted do not use a standard replacement. Mine are Moog, they have grease fittings and work fine. I am sure the ones the other person recommended are good also.
ok thanks. so do you think those are the mounts or the front swaybar links. Also is it bad that I drive on it? I mean I dont have the money right now to fix it, but I dont want to continue to drive on it if it will make things worse or a bigger problem in the future
drummer829 is offline
