Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - new here
Thread: new here
Old 01-31-2013, 04:31 PM   #5
focusmaniaczx3
I need BOOOOST!!!!!!
focusmaniaczx3's Avatar
Fan#: 55157
What I Drive: zx3 turbo, kia soul, 71 chevy c/10
Points 16,617, Level 82
Points: 16,617, Level: 82 Points: 16,617, Level: 82 Points: 16,617, Level: 82
Level Up 54% Completed
Forum Activity 6%
FF Reputation: 35 focusmaniaczx3 Great Standing Member
Buy-Sell-Trade Rating: (14)
omg dude your grammar is killing me! use punctuation! or at least periods or something. my inner grammar nazi hates run on sentences.
the throttle response that you feel is purely a placebo effect unless there was something seriously wrong with your stock coil in the first place. the msd coil and plug wires are in no way better than factory and actually are a hindrance. with the msd coil you cannot get an accurate torque reading on a dyno which is infuriating if you want to see what kind of difference your mods have made. the stock coil pack and wires will support over 700whp just fine. no need to change it, but since you already have it you may as well keep it unless you want to try and sell it on the BST section of this site to try and recoup some of the money you spent on it.
the SVT header is a good mod. it will net about 15whp every time. you NEED a SVT flex pipe, SVT cat (or off road pipe/cat-delete pipe if you can get away with it) and a way to protect your power steering line from the heat from the exhaust. you can either move the line or wrap the crap out of the header and everything. otherwise you run the risk of exploding the line while driving one day and loosing power steering. also you dont NEED a SVT dipstick and tube. you can simply bend your stock tube however some people dont have much success with this technique and end up breaking the tube in the process.
you will want to run at least 2.25" exhaust but you will benefit more from running bigger if you get the SVT header. the SVT header makes the most power if it is run open header with NO exhaust at all. unfortunately this is very illegal and very loud on the street. this means that anything after the header is just going to be a power restriction and nothing else so the more free flowing you can make the exhaust the better. 2.5" is probably the most common choice. it flows decent and sounds good. 3inch will be best but its hard to make a non turbo car with 3inch exhaust sound like anything other than a rice rocket. 2.25" is pretty much a waste of time and money but if its what you want then go for it.
stay away from underdrive pulleys. waste of time and money.
stay away from miracle hp and fuel economy increasing chips. scams, one and all. same thing goes for electric superchargers, and those little fan looking things that are supposed to spin the air in your intake. and throttle body spacers are a waste as well unless you are going to use it to drill and tap in a nitrous solenoid. that way you dont have to drill a hole in your intake and you can remove it in 5 minutes.
look up the ralco short throw shifter. if there are still any out there for sale they are the cheapest STS out there for the focus. i have one, ive had it for years, and i shift gears like hulk and i still have not broken it and it cost me about $50. best bang for your buck STS there is. be careful though about getting the right shifter. the design changed halfway through the 2002 year so there is a 2000-2002.5 and 2002.5-2004 design. since your car is a swap job i imagine it could be either type so you SHOULD pull out the stock shifter and examine it very closely before you buy.
i hope my book helps
focus-power P&P head $1100
focus-power DIY turbo kit $1495
tom's first time in Vegas? PRICELESS!
Originally Posted by 1turbofocus
I love this big little city HOOTERS !
Back from the dead with very few f***s left to give.
focusmaniaczx3 is offline
