Old 01-30-2013, 09:16 PM   #1243
thejordan
thejordan's Avatar
Fan#: 107706
What I Drive: 2013 SGM Focus 5 Speed
Points 1,434, Level 21
Points: 1,434, Level: 21 Points: 1,434, Level: 21 Points: 1,434, Level: 21
Level Up 34% Completed
FF Reputation: 4 thejordan Good Standing Member
Originally Posted by erogers10287 View Post
High strength fishing line. I recommend using gloves (so the wire doesn't cut into your skin) and just pull the line behind the badge and it should cut the adhesive. Then you want to take sticker remover or even buffing compound will work to get the glue off the paint.
Nope.
Heat up badge with hair dryer, use floss and sea saw away. Heat up as needed. Peel off the remaining adhesive, heat as needed. Use a little glue gone on a towel to remove any residue. Apply wax.
Edit: raf beat me to it
thejordan is offline
