Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How successful is using Dynamat?
Old 01-30-2013, 12:32 PM   #46
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
What I Drive: 2004 highly modded Mini Cooper S
Points 7,547, Level 57
Points: 7,547, Level: 57 Points: 7,547, Level: 57 Points: 7,547, Level: 57
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 24 freemind Great Standing Member
Buy-Sell-Trade Rating: (23)
Originally Posted by Njk570 View Post
Also note though, most people misunderstand what Dynamat, Second Skin, Peel and Seal, etc is really for. All that stuff really does is add weight to panels and what not, to prevent them from vibrating more. More weight= less vibration. Yes, it will help with road noise slightly, but its not the best route to take if you wish to kill outside noises. Second Skin makes something thats called Luxury Liner, which is a layer of foam almost that you roll out in the car. I would recommend apply that to your floors and whatnot if you want to really "deaden" the car.
02Zetechse covered that.
When my windows are up, you can barely hear my system on the outside. Which is good because it decreases the chances of my system getting jacked.
Covering deadener with Ensolite(closed cell foam)helps a lot also is a good(cheaper)option as well. MLV(Mineral or, Mass Loaded Vinyl)is a great option as well. But getting it to stick on things that are not the floorpan can be tricky.
133whp-126ftlbsTQ Eclipse CD8443,Eclipse PA5422, JBL GTO751EZ, PPI 356cs(Rebranded A/D/S 346cs), JBL p1024, SubThump enclosure, RAAmat BXT, Damplifier Pro
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
