Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Who makes this wheel and will it fit?
Old 01-30-2013, 12:02 PM   #7
drewts86
Fan#: 72974
What I Drive: 2004 Burgundy ZX3
Points 612, Level 12
Points: 612, Level: 12 Points: 612, Level: 12 Points: 612, Level: 12
Level Up 24% Completed
FF Reputation: 1 drewts86 Good Standing Member
Originally Posted by HotRodWagon View Post
No, you need 5x108 wheels. For an 18x8.5" wheel, 45mm offset is a flush fit. 35mm will extend the wheel just outside of the fender, more pronounced in the rear.
If lowering is in your future, and want an 8.5" wide wheel, look for something with an offset between 45mm and 48mm. Also, a good set of coiliovers will be necessary to dial in the right amount of drop.
HotRodWagon is correct in the offset numbers, but you can still run the Rotiforms. They can make whatever wheels you want in custom spec with whatever offsets you want. You can get them in 4x108 or 5x108 if you so choose as well, but their website lists the wheels at $1250 each - so unless you're flush with cash.....
drewts86 is offline
