Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 05 focus Squirrely back end in snow
Old 01-29-2013, 03:51 PM   #12
Julian@TireRack.com
Fan#: 102247
What I Drive: N/A
FF Reputation: 2 Julian@TireRack.com Good Standing Member
Originally Posted by petermb72 View Post
THANKS! Glad to be here. Don't suppose I should adjust my self? This is a computer/machine type adjustment on a rack I assume?
That's a loaded question...
CAN you do it yourself? Sure, you just need to turn the tie rod end one way or the other to push out or pull the wheel/tire into the right place. SHOULD you do it yourself? It's nothing I would want to "try" and see if I did it right, then go back and keep trying.
I would take it to a good shop and make sure you get the read outs of before and after the alignment so you can see what setting they should be at.
888-428-8355 ext. 4798
Remember to reference Julian/Focus Fanatics in the "previous contacts" field to make sure the forum get's credit!
Julian@TireRack.com is offline
