Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Problem with Engine:
Old 01-29-2013, 03:35 PM   #2
jugglethese
jugglethese's Avatar
Fan#: 108852
What I Drive: 2007 focus gloss black SAP zx3
Points 1,778, Level 24
Points: 1,778, Level: 24 Points: 1,778, Level: 24 Points: 1,778, Level: 24
Level Up 78% Completed
FF Reputation: 1 jugglethese Good Standing Member
When i was reading i thought it was the fuel pump but you figured that out. Possibly run a compression test. its like 20$ for it and you plug it into the spark plug hole and let the engine crank over a few times. after you do all 4 cylinders (i dont know what the compression should be, someone here should know) that will let you know if your engines still good. Go to a shop and run a diagnostics check on your car. the person there will know what your talking about if you dont. that will rule out some more problems you think you might have. Thats pretty much all you can do for a cheap amount of money. and if that fails, its time to buy a new car i guess. hope this helps alittle :)
jugglethese is offline
