Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Can anyway explain to me why my spark plugs keep backing themselves out?
Old 01-28-2013, 03:56 PM   #17
amc49
Fan#: 96610
Points 6,928, Level 54
Points: 6,928, Level: 54 Points: 6,928, Level: 54 Points: 6,928, Level: 54
Level Up 89% Completed
Forum Activity 100%
X2 to the last two posts.............
9-13 ft.lbs. is the spec, I would never go much over that, doubling up on the torque is simply asking for pulled threads since they are now worn.
Normally angle seat plugs get TIGHTER as they run, your loosening is probably a result of all the plug yanking you've done in the past. Those aluminum threads get a bit looser every time you go in there..................
Ted, went to your site and looked at the youtube on pass side mounts, the differences are not so much outside as inside, I've had several apart........I really hate that Anchor mount...............
amc49 is offline
