Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Headlight lens restoration? Is 3M the best, or what?
Old 01-28-2013, 08:27 AM   #3
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
What I Drive: 01' Yellow ZX3 euro, 04' ZX5 SVT
Points 158,473, Level 100
Points: 158,473, Level: 100 Points: 158,473, Level: 100 Points: 158,473, Level: 100
Forum Activity 14%
Activity: 14% Activity: 14% Activity: 14%
FF Reputation: 51 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
I dunno which one to tell you to use. I used the Mequires restore kit, but I've found hitting it up with some very fine sand paper before really helps.
I took a headlight that looked like this and felt like sand paper
Sanded with 800grit, then 1000grit, and finally with 2000grit in a criss cross pattern so as to not making any gouges or marks.
Once that was done then I started using the polish and buffing pad that attaches to the drill. This is half the light done.
Just about done and used the micro fiber towel that came with the kit for final polishing by hand just like the directions say
Here is the end result
Depending on how bad the light is I would maybe start with a much higher grit like 1000-1500. The light you see was in very bad shape but came out fantastic. I do suggest doing something to the light to keep it that way. A lot of guys like to use lmain-x or some sort of clear coat to keep them from oxidizing and getting that way again.
I started out with nothing and I still have most of it left
Hatch Nation #15 (Ole' Yeller') & #150 (The SVT)
Moderator for
sleepyboy is online now
