Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Stock shifter on a focus, can be turned into short shift free
Old 01-28-2013, 06:10 AM   #2
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 MX-5 and 09 Focus Coupe
Points 14,818, Level 78
Points: 14,818, Level: 78 Points: 14,818, Level: 78 Points: 14,818, Level: 78
Level Up 92% Completed
Forum Activity 8%
Activity: 8% Activity: 8% Activity: 8%
FF Reputation: 30 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (50)
Moved to "Duratec Performance". While it may be a cheap mod it's not very practical when the boot won't even fit on there properly. And you said it was banging on the front of the console from where you raised that part to high. I know some people have actually cut off about an inch or two from the shifter and added an aftermarket knob. It has the same principles as an aftermarket short throw shifter, making the shaft shorter. But with the aftermarket STS you have the advantage of everything fitting properly and you can put your old shift knob back on without any problems.
zetecDon is offline
