Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - adding power...
Thread: adding power...
Old 01-27-2013, 09:21 PM   #9
drewts86
Fan#: 72974
What I Drive: 2004 Burgundy ZX3
Points 612, Level 12
Points: 612, Level: 12 Points: 612, Level: 12 Points: 612, Level: 12
Level Up 24% Completed
FF Reputation: 1 drewts86 Good Standing Member
Windows and locks are fairly easy to install. I would recommend that if you are going to do the install of all the parts yourself, then you should go to a junkyard that will let YOU pull all the parts you need off yourself. That way you get a better understanding of how they will be going into YOUR car. Taking something apart is the best way to learn how to put it back together. If somebody else takes it apart for you, you might not be able to figure out how everything goes back together. Also, if this is a first time kind of thing for you, don't be afraid to pull out your phone and take lots of pictures. That will give you the ability to go back and see how things are supposed to look.
drewts86 is offline
