Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Is it possible ? Bad compression on SVT
Old 01-27-2013, 06:48 PM   #4
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,294, Level 100
Points: 32,294, Level: 100 Points: 32,294, Level: 100 Points: 32,294, Level: 100
Forum Activity 4%
You can use the Zetec bottom end, but I fail to see how that would be easier than simply swapping out rings.
I don't know if using a Zetec bottom end with hi-comp pistons would work. Surely if you have one built already, the person who built it with hc pistons would have put forged rods in. Now if you were wanting to build a Zetec while keeping your engine in the car, then taking yours out, swapping the head and intake over, then installing it in the car- I can understand. You'd probably want to used forged rods too, and this method would be more expensive than using your SVT block since it probably doesn't run with only 85 psi on one cylinder. Besides, you don't know if it's pistons that are the problem right now or valves, so you'd have to had the head worked on also.
The only reason to go to a dished piston is for future forced induction plans, so the engine can handle more boost. Forged rods and pistons required- obviously. To go to a domed piston, I'm not sure. You need more of an expert than me. It's possible there is an 11.5:1 set out there that will work with the VCT, or cams can be used that are designed to work with those pistons and without the VCT.
I think this is a question best answered in the SVT forum, not in Gen Tech Chat.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is online now
