Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How To: Add Rear Head Rests
Old 01-27-2013, 05:25 PM   #5
FordNLNR
Fan#: 96745
What I Drive: '03 Comp Orange SVT / '03 ZTW
Points 450, Level 8
Points: 450, Level: 8 Points: 450, Level: 8 Points: 450, Level: 8
Level Up 50% Completed
FF Reputation: 2 FordNLNR Good Standing Member
I just did this on my '03 Wagon. Ford part numbers for the plastic tubes/guides:
1S4Z.54610B16.AA (RH)
2M5Z.54610B16.AAA (LH)
One each needed per headrest.
After taking the seat out and apart like originally decribed, I realized that it's more easily done inside the car without any dissasembly at all! The holes are already in the foam pad. Feel around and you can make a depression in the upholstery cover where the guide tube will go because the foam padding is already cut out. I inserted a straight pick into where I thought was center, then moved it around a bit to feel the seat frame and how close my estimate was. Out of 4 holes I made (didn't want a center headrest), I was only 1-3mm off center with each initial probe. Enlarge the upholstery oppening little by little until you can get the guides tubes to fit - press down to snap into place! Looks factory.
FordNLNR is offline
